ORIGINAL: can773
ORIGINAL: gaRCfield
My other 1st choice is the Xtra 30-10. I don't see the need for the Advance - everyone seems to be dialing it back, so why would it be worth the extra oz (for me)?
Advance had better bottom end, more efficient, runs much cooler, mounting is lighter and more rigid, and it will swing a bigger prop than the evo without getting unhappy.
Interesting about the mounting! If the end result is equal or less weight, then it's a no-brainer. Thanks Chad, I'll look into it
(20min later...) Wow - nose ring mount for the Advance?!?! Easy and light, I like it!! So that or the Hacker, but leaning on the Advance now.
