RCU Forums - View Single Post - Receiver
Thread: Receiver
Old 07-04-2012 | 06:24 PM
riot3d
Default Receiver
Bax or Krysta,
I'm planning to outfit a bi-plane which requires 8 servos plus an ignition unit, & will be using a 18 MZ.
I'm planning to use the R6008HS which will use up all 8 of the servo ports. However, can I plug the ignition unit onto the data port? If not, I also have a R7008SB. If both rx is not suitable, which rx do you recommend for this application? In addition, I'll only be using BLS servos, no HV or any SB units.
Thank you,
Adrian
