RCU Forums - View Single Post - Different engines, Glow, Gas, please explain.
Old 07-09-2012 | 07:39 PM
SeamusG's Avatar
SeamusG
Default RE: Different engines, Glow, Gas, please explain.
The air frame manufacturer will provide you with their recommendation. Like I said, they call 'em 40 size, 60 size 120 size airframes. That means - use a 2-stroke .40 (or equivalent 4-stroke), use a 2-stroke .60, or a 2-stroke 1.20. You can usually upgrade a size but beware that the progressively bigger motors weigh more, are longer and wider, and require bigger mounts. There will come a point where a bigger motor / mount configuration just will not fit or is so friggen heavy that you'll have a real over-powered turd on your hands that won't perform anywhere near the way the designer intended.
Bottom line - you can bolt up as much HP as you want to pay for.
Oh yea - you being at sea level you can follow the manufacturer's suggested engine sizes. I'm at 5900 feet - IMUSTupgrade to come close to the "designed for" performance envelope.
