RE: Windshield washerpump ?
Bobhend
Thanks for the reply. I ended up purchasing a $14 univeral pump at Autozone just prior to your reply. Seems to work well for fueling and unfueling and I try empty the pump when not in use in case there is a reaction with the alcohol. Time will tell if it starts to fall apart and leak.
You are right in that there is a need for an affordable low end pump.
Dave
