RE: Li Fe Batteries?
Scale
I told you I use an EOS Sentry I bought from Heli Pro's.
If I discharge to 20% of an 1800 mah pack that mathematically figuires to be 360 mahs. I when I use my "worthless charger". I use a timer to keep track of the mahs going back into the pack at a mah setting on the charger. Example, set charger at .5 mah or 500 mah. That means in one hour the charger will charge 500 mahs. I keep track of the minutes until the charger peaks and that tells me how many mahs I put back into the pack.
Sounds complicated, but it isn't. Just use the math from school.
Kirby
I want to see it for sure.
Darrolair
