RCU Forums - View Single Post - Li Fe Batteries?
Old 07-11-2012 | 06:18 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Li Fe Batteries?
So all you are figuring is 20% of what the pack is supposed to be based on it's Voltage,, you still have no way of knowing what the packs true capacity is. That X% it's showing is only based on a formula of the range of voltage for said pack. That's why the percentage will change when you switch chemistry settings. At best it's a guesstimation, both my chargers have a similar feature and they are never display the same %.
You will only know the true capacity if you cycle the pack.
and you miss quoted me,, I said "It's useless for evaluation of a packs condition",, not worthless
good luck, Scale out
