RE: 10cg Expo programming question
Hey thanks BAX, yes this pix is my transmitter. Well I was thinking the graph should only look like the upper right portion of the graph only, but gave it alot of thought and figured that was only one direction travel for the surface, and the bottom half of the graph is the travel in other direction. Am I correct? At any rate I've flow the airplane it seems to work correctly removing alot of twitchy-ness.
