Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
10cg Expo programming question
Old 07-04-2012 | 10:27 AM
Default 10cg Expo programming question
Hello all, Where I am I going wrong, I'm trying to setup Expo, but I'm getting something that looks nothing like the bar graph should look like? (see pix). I do have a mix for dual channels on Ailers, but this is the Elevator setting? Or am I way off base, I've been reading and searching here for 3 day's with no avail. Any help here would be greatly appreciated. Thank you.
Old 07-11-2012 | 06:06 AM
Bax
Default RE: 10cg Expo programming question
The picture shows the correct curve for exponential where you want the controls to be softer in the center of stick movement.
What do you think it should look like? Is the picture from your transmitter?
Old 07-11-2012 | 06:55 AM
Hey thanks BAX, yes this pix is my transmitter. Well I was thinking the graph should only look like the upper right portion of the graph only, but gave it alot of thought and figured that was only one direction travel for the surface, and the bottom half of the graph is the travel in other direction. Am I correct? At any rate I've flow the airplane it seems to work correctly removing alot of twitchy-ness.
Old 07-12-2012 | 06:41 AM
Bax
You are correct. The graph shows center to one end, and then center to the other end.
