Super Tigre 61, Ringed or ABC
Frankly there is little difference between the 2.
ST quote .1 of a horsepower difference. Probably a couple of hundred rpm, with identical props.
What sort of model do you intend for the motor?
If it's a scale or semi scale with a cowl, probably the ringed version. If it's something that is going to tear up the sky, the ABC.
Also consider what Dar Zeelon has said about life span.
