RE: Sterling 48
There’s nothing like Rustoleum for a good finish. Out to the garage again for a heavy coat of primer. Because it was foggy, I brought the boat in to the house where I have a dehumidifier going in order to reduce the humidity and raise the temperature. It was 76 degrees and 45% humidity. After an hour, it was out to the garage for a very wet coat of white. Back in the house for an hour and then to the garage for another wet coat of white. The sun did come out so I let each side soak in the sun for two hours. The paint was dry to the touch and I was able to remove all the masking material. The result was just what I was hoping for. I’ll let it dry for another day and then I’ll mask it off for the bottom paint. Dan.
