RCU Forums - View Single Post - Need help with a foamy
Old 07-19-2012 | 04:32 AM
Sherv
Default RE: Need help with a foamy
These are great options and I know from word of mouth they are great.
Fast-
Radjet 800mm from HK. Batteries are cheap too from HK but you need a lipo balancing charger
It uses epo foam so it is durable and with a careful hand and a blow drier you can make epo bounce back or if your summers are hot then leave the plane out on the deck and it will bounce back into shape.
http://www.hobbyking.com/hobbyking/s...00mm_PNF_.html
Glider -
This plane can go 60mph on the stock battery and do aerobatics plus I get 10-15min run time per battery.
http://www.hobbyking.com/hobbyking/s...dProduct=16568
need esc (30amp), batteries, and 4 9g servos for this plane but those dont cost much on hks website. Also lipo balancing charger.
3d -
An Edge 540 800mm
Regardless of what plane you buy from what ever company, I suggest you buy your charger and batteries from hobbyking and save a huge amount of money. HK Turnigy batteries are great, I have 8 3s 800mAh, 4 3s 2200 mAh, 8 2s 5000 mAh, and 4 4s 3200 mAh turnigy batteries and only 2 of them puffed because I was drawing more power than they were rated for (oooops) but now I have a watt meter to check the Amps my setups are pulling to prevent that from happening again.
I had a 3rd one puff too (2s 5000) but that was because my Savage Flux flew into a tree sideways (battery compartment) at full speed.
