RCU Forums - View Single Post - Which ICU for 45 IRS
Old 07-19-2012 | 02:54 PM
pe reivers
Default RE: Which ICU for 45 IRS
There is nothing wrong with your pictures. You must use the old Vlach ignition lower boot, and use the conversion ignition and brisk plug with sawed off top. They will fit. Without the Vlach lower boot, nothing will fit.
If you saw off the top of the tapered seat 14mm thread plug, that will also fit if using the Vlach lower boot..
