RCU Forums - View Single Post - Interference problem HELP please
Old 07-19-2012 | 04:56 PM
bluejets
Default RE: Interference problem HELP please
Never found it necessary to use shielded cable if the noise suppressor plug was used and eliminate the steel throttle link.
You've kept radio gear isolated best you can so I would try that first.
Shielding would be a final application if all else failed.
TV Co-ax will not be suitable as it is designed for TV signals at very small voltages, maybe just a few millivolts.
Ignition systems operate at thousands of volts and the co-ax does not have a high dielectric strength. i.e. the spark will jump across the insulation to the outer shield under load.
In days gone by, the co-ax cable had a fairly loose shield that could be removed quite easily and re-applied to another cable but these days, co-ax is quad shield and the shield is moulded in the cable and would be impossible to remove as once-upon-a-time.
