RE: Disconect allerions on a trainer 40 ?
If you lock them square and the dihedral is sufficient it might work. If you get them off or there isn't enough dihedral you could be worse off (having no way to correct roll).
It is also easier to bank with ailerons than rudder, but turing when taxiing requires rudder.
