Control Rod Possibility
Builders:
Has anyone out there CA'd wire into the inner control rod tube and made it stay? Seems if the wire were cut off with the threaded end protruding and about 1/2" of the smooth wire were glued into the inner tube of the same size, it would be an easy solution to hooking up servos, eliminating Z-bends and screw lock connectors that have such a bad rap. Anyone?
Max
