Which 50 Cc To Use?
I've had the ZDZ50, DA50 and Taurus 52 in my hand... for narrow cowls the DA appears to be the smallest... the Taurus is shoter but has a side mount carb...
the ZDZ isn't much bigger than the others...
So I guess I'd say the DA-50 (and any other rear carb) would be a safe bet... AS LONG AS you have the space lengthwise... if not you need the ability to put a whole in the firewall for the carb to set back in...
Also Brison has a new Revolution 50 that has a rear carb and LOOKS alot like a glow motor...
Check it out too... they are all priced about the same.
