ORIGINAL: Correy
Hi,
Doing some research on this heli before I purchase one and I have a detailed transmitter setup (thanks Tom Z) but can't find any info on how to perform mechanical setup. Can anyone point me to a setup for that? In addition, I noticed there is an adjustment switch on the receiver (next to the axis switch) that isn't explained very well in the manual.....what is the purpose of this switch and is it related to the mechanical setup?
Any advice is appreciated!
Correy
that is freaky as crap, thats my name!!!!!
anyway, I would leave that switch alone, if i remember right, get your trim dead center and then make sure the swash plate is as flat as possible. then spin it up while holding it and check blade track, if you see a blade spin higher or lower than the other, mark the blades, adjust one blade accordingly ( by tightening or loosening the link a half turn at a time) its kinda trial and error, you can take a TINY strip of colored tape on each blade one farther in than the other, and you can tell which blade needs adjustment.
