RCU Forums - View Single Post - SYSSA 30CC GAS MADE IN USA
Old 07-24-2012 | 07:56 PM
  #5164
opjose's Avatar
opjose
Default RE: SYSSA 30CC GAS MADE IN USA
ORIGINAL: JeffinTD
It has only flown twice. Both resulted in dead stick, but smooth landings.
The only other ignition module I have is for a DLE55.
Anybody know if the Syssa will run with the DLE55 module?
When they ran it, they put it on their own test stand and used their own tank and plumbing.
Given that it is not running nor starting right for you, I'd start there, especially since your problem seems to get progressively worst...
e.g. you flew, then deadsticked, now it will not start.
Re: Module
I've often replaced and interchanged modules between engines w/o problems.
Just take care to heed the max voltages permitted, as some modules are more sensitive than others to overvoltage conditions.
