RCU Forums - View Single Post - Placement and horns
Old 07-25-2012 | 09:41 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Placement and horns
ORIGINAL: bohiaa
Yea, I set mine up this way, however I didn't know to put the kill switch on the oppsite side of the ingition box,
Also, I figured I would just use the ignition switch on off switch as a kill switch. Is this OK ?
Thaks again
Why do you feel the switch needs to go on the other side?
You "can" use it as a kill switch but you'd be better off using a transmitter activated optical kill IMO
Edit: There's lots of ways to accomplish the same thing in this hobby, do whatever makes you comfortable. Certainly following the old school methods won't lead to you failure any sooner than modern methods.
