RCU Forums - View Single Post - Windshield washerpump ?
Old 08-04-2012 | 02:55 PM
  #41
Chris P. Bacon
Banned
Default RE: Windshield washerpump ?
ORIGINAL: djstar39
I use the Boxxer pump and has always worked great but is now taking about twice as long to fill my planes. Went to find the rebuild kit but apparently they're not available. Might have to try the MKIII.
Dave
Have you tried contacting Slimline directly? You should be able to purchae a rebuild kit directly from them. My Slimline SL-2000 pump is the best pump I have ever owned. Since it's a peristaltic pump so it's self-priming and your fuel never leaves the fuel tubing as it does with a geared pump. My pump must be about 10 years old and I only used a rebuild kit once. It was a done as a precautionary measure about three years ago, not because the tubing in the pump had failed.
http://www.slimlineproducts.com/
