RCU Forums - View Single Post - Volt spy question
Old 08-06-2012 | 06:48 PM
freakingfast
Default RE: Volt spy question
ORIGINAL: tomfiorentino
ORIGINAL: freakingfast
{clip}
Every status light type I've used blinks for the briefest of time the red light if I quickly circulate both sticks at the same time.
{clip}
OK...and this means there is a problem. If it does this on a full charge, the battery is having trouble meeting the voltage demands of the servos. (ie. either binding, extensions too long, bad switch, too many servos for one battery etc. etc.)
Tom
Still waiting for that voltage "problem" that causes a crash or control issues. Perhaps sometime in the next ten thousand flights. Have I retired sick packs? You betcha. Thanks to voltage/load test meter, status lights and capacity test when suspect.
