RCU Forums - View Single Post - Volt spy question
Old 08-07-2012 | 06:27 AM
  #35
tomfiorentino
Default RE: Volt spy question
ORIGINAL: rgburrill
ORIGINAL: JohnBuckner
ORIGINAL: kuobin
,but the blinking happens only when i execresing,when i release sticks ,it backs to green.
Thats because the currant draw increases when you are wiggling those sticks and goes back to idle when you stop wiggling.
As CGR suggested to find out which control may be binding a bit just wiggle them one at a time.
Now to answer your question as to whether or not to ''go back to Nicd'' you need to tell us what is the battery capacity of your battery, not just the voltage.
These days I only use five cell batterys (6 volt) and for an ordinary forty sized sport plane using a 2.4 system I prefer to use a minimum of about 1600 mah.
John
5 cell, 1600mah? Just how did I survive with a 600mah, 4.8V NiCd? Let alone fly 4 times per day without a recharge?
Hey....you can still survive on that today if you want to as long as you aren't running digital servos.
Many guys have elected to pursue the performance gains of digitals and/or have exploited the longer run times and performance gains of higher capacity and voltage packs.
But you can still survive on the 4.8 NiCd 600mah if you wanted to...no question. There are tons of ways to skin this cat!
Tom
