ORIGINAL: tailskid
Kits should be noted as BYO (build your own) or something along those lines...ARF's should be listed as 'assembly required'. That ought to confuse us even more
Yea...until the build your own nomenclature offends the guy that happens to plant balsa trees from seeds, which he waters until mature, rough cuts, mills, dries and prepares nominal lumber from...all to be used in his kit! [X(][X(]
