RCU Forums - View Single Post - Flyzone Select Scale Super Cub
Old 08-07-2012 | 06:31 PM
freeonthree's Avatar
freeonthree
Default RE: Flyzone Select Scale Super Cub
The landing gear on the Select Scale Cub is amazing. I've had some funny landings that moved the suspension a good inch.
I wish they had used two servo's for the alerons so we could use flaperons.
I thought the horizontal stabilizer was a bit flimsey, so I added support rods underneath. They really tightened things up.
I also added a rubber band around the fuse and the rear tab of the wing to hold the rear of the wing down against the fuse.
I need two more batterys, 4 isn't enough. Im thinkin 6 would be about right. lol
