RCU Forums - View Single Post - Top Flite Redbox P-51
Old 08-10-2012 | 02:36 AM
Toysareforkids
Default RE: Top Flite Redbox P-51
Do yourself a favor and don't use the belcranks on the ailerons. I almost did, and I'm glad I was talked out of it.( after I had the wings halves glued together, and all sheeting on, except the top back half.)I've never had a problem with belcranks, but if you do or they wear and get loose, you'll have to cut open the wing to fix them. Plus their more positive, and no slop. I still use the belcranks on the flaps, which work good, butwould have been better with servos there also.
Pat
ID:	1790650   Click image for larger version
