RE: Lancair 360 MK2
Hello, I know this seems a little late but I have had this plane for about 5 years and can't really find any info on it anymore. I think it's probably discontinued. Anyway, I finally got around to finishing this CMP Lancair 360 MK2. I was running a brand new OS 46 AX in it. The maiden did not go to well. After take off the plane was really twitchy and hard to control. I had the CG set on a great planes CG machine at 72mm without fuel. The control throws were only set for 8mm EL and 8MM AIL. Rudder was max throw. I was using a 12x6 prop. The plane didn't seem to fast on the ground but it took off after a long takeoff roll. Once airborne it seemed really hard to control and I eventually lost control and crashed it. Almost like a radio problem. I repaired it overnight and went to fly agin the next day and it was even worse than before. I was just wondering if you recall any tips for this plane and if you may still have it. CG, Throws etc..
Thanks in advance,
Rich
