RCU Forums - View Single Post - Rx-18 control order problem
Old 08-18-2012 | 06:30 AM
Rock1997
Default RE: Rx-18 control order problem
Hi all,
I can spin left and right. no probme at all. also I can slowly turn left with correct track order. However, If I want turn right slowly, only right track moves backwards and left one keeps still unless turnning fast. I have tried to adjust the trim on three radios and the problem still exits. I didnt change gearbox on any tank and they all have their original gearbox installed. Also, I found left track has bit delay when it is moving forwards at balanced trim. Its quite annoying that three tanks have the same problem even 2.4 Ghz one.....
<br type="_moz" />
