RCU Forums - View Single Post - Prolog
Thread: Prolog
Old 08-19-2012 | 02:49 AM
svrcp
Default RE: Prolog
from the rear lower corner of the canpony forward, 260 like they call for should put you aft of wing tube. At 270 you will be right at back side of tube , I started out at 280 and believe ended up around between 270-275mm, not quite center of tube. Which motor are you using. Like you said at center you'll be safe.
Jr
