ORIGINAL: SBOT Has anyone used the HPP-22 to display flight data on a computer. If so; how did you do it? I can not get mine to work. This is what I have been doing: After following the instructions from the HTS-SS 2.4Gz Telemetry Product Installation Guide, Page 5 HPP-22 PC Interface, at step #4 Turn on Aurora and select “OK” to transmit, I notice that my Aurora 9 boots up in ppm mode. Then at step #8:
As the target select SPECTRA 2.4 Module The HPP-22 screen does not prompt me to select: “Sensors data display?”, but instead goes to the regular HPP-22 firmware upgrade screen. Instructing me to plug in the cord to slot #1 on HPP-22 and plug the other end into the Spectra 2.4Gz Module etc...
What am I doing wrong. I have the following firmware ver.
HPP-22= ver1.12 Rec Optima #7 = ver 2.02(0)
Trans Aurora 9 = ver 1.08(1) 2.4Gz Rf Module = ver 3.01(0)
Thanks for any help anyone can give Oscar
There was a change when the Hitec Telemetry System Command Centre was updated.
Telemetry - Instruction Sheets & User Guide with pictures
plus Enhancements Under Development.
(a copy of the updated manual attached hereto)
Following same manual/procedureas above, my A9 also stuck on "PPM".
Neither HTS-SSnor the Blue sensor here tonight so reconnected HPP-22 to module and PC but did not activate A9.
Opened HPP-22 program and then clicked on "Hitec Telemetry System Command Centre", selected HTS-SS,
then HTS-SSBLUE display.
Finally turned on Aurora 9 and hit the "Yes". LED changed to Red and on screen Icon to "AFHSS On Air".
With your sensor installed in your model, you should then be able to activate thedisplays on screen.
If above does not assist, please email your distributor direct and, to assistothers,update this thread with results.
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada.
(- Closed Weekends)
"1"]• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
