RE: Info from Data Terminal after a shutdown
Hi Ian - Pump was repaired but returned without new plastic shielding which I wasn't too impressed by. I'll try to do a video'd test run tonite over 5-6 minutes and see if I get a flameout.
One thing I would like clarified. The very end of the turbine is well into the bell of the exhaust pipe. Is this OK?
Barry - Can you look up the serial number based on what Ian says above? Does it have any bearing on the problem?
