RE: Info from Data Terminal after a shutdown
Just did a test run of 7 minutes. Full power for couple of minutes at a time a no problem.
Before start temp 24DegC. Idle RPM 34K. Max RPM 114.5K at 476DegC.
Sound OK? So frustrating when the same problem can't be replicated on the ground.
What would be different in the air?
