Most if not all blue-print shops, and many print-shops can scan plans and put them into any format you want these days.. Sometimes for just a few bucks... Scanning is no big deal cost wise.. its the output that can cost you.. depending on the size you need. Let your fingers do the walking and start with blue-print shops.. if they're to far away.. try a local print-shop.. I actually work in a print-shop that does this sort of thing daily... we can scan nearly any size plans.. not that it does you any good.. but you'll find someone close to you I'm sure.
