RCU Forums - View Single Post - Kitbashapalooza on a HK predator
Old 08-26-2012 | 10:34 PM
edgeflyer
My Feedback: (15)
Default Kitbashapalooza on a HK predator
After being talked into building a nightflyer, I wanted to do something diferent and cool. The predator definatly fit the bill. I bought the HK predator, and 12 strips of lights. It would be recovered in white. I also was convinced I would stick my spiderweb infested .15 size eflight retracts in it for a nicer plane. The bottom of the plane will be filled in flat for scale lines, and also happen to help hide the gear when retracted. The Predator's build was as cheap and poor as I had read and thought it would be. One out of 6 ribs were actually glued in. The rest were held together via ultracoat. I see now why broken wings are common. I decided to use my park 480 with a 3 blade for scale. The plastic was sanded for weight and repainted. The plane is almost done now, but I intended to start the build when I started the plane. With an hour of ups showing up, it was just a skeleton.
Started cutting a hole for the nose wheel to fit.Fitting the main retracts Added a carbon spar to make the wings removable. Also glued the garolite spar that came with the kit into the fuse to give the center of the fuse the strength it would need.Also started adding lights Tailsection recovered with lights installed under the covering.
