RCU Forums - View Single Post - ys175
Thread: ys175
Old 08-28-2012 | 05:41 AM
apereira's Avatar
apereira
Default RE: ys175
Hello Drac1,
It work as Robert said.The YS ignition fires every time the sensor is exited, I actually move the prop back and forth about 20deg and the ignition fires every time I cross the sensor, the DA engines ignition I think works as you say as it has to have some speed (achievable by hand), if the prop is moved slowly it will not fire, but I am not sure, it's been a while since I ran my DA100.
You ,ight have a problem with your ignition if it is a YS.
Regards
