RCU Forums - View Single Post - Which is lighter CA or Titebond?
Old 08-28-2012 | 12:25 PM
BillinIndiana
Default RE: Which is lighter CA or Titebond?
ORIGINAL: RCKen
<div></div><div>Every plane that I've built I always use epoxy to join the wings with. While it is possible on some planes to glue the wings together with just wood glue, you're better off using the epoxy. Follow the instructions for the plane and use the glues that are recommended. And in this case the instructions from Sig call for using epoxy to join the wings.</div><div></div><div>Ken</div>
So far all the SIG instructions have said is to "Glue" It has never mentioned "Use Epoxy or CA" in anything I've read.. So far anyways. I've really just started and am taking my time.. I just sanded the ribs on Step 8... I see a pic on Step 32 pic 30 that actually shows him using the SIG Bond, which if I'm reading the Info right from the SIG website is wood glue..
Scroll down to Step 32
<a href="http://www.kavanrc.de/instructions/sigrc49kadetmkii.pdf" target="_blank">www.kavanrc.de/instructions/sigrc49kadetmkii.pdf
</a>
SIG Bond info page
www.sigmfg.com/cgi-bin/dpsmart.exe/DetailProduct.html
<br type="_moz" />
