RCU Forums - View Single Post - Which is lighter CA or Titebond?
Old 08-28-2012 | 01:20 PM
  #32
BillinIndiana
Default RE: Which is lighter CA or Titebond?
ORIGINAL: RCKen
Bill,
Step #44 clearly states to use epoxy to join the wing halves together.
<div style="margin-left: 40px; ">43.</div><div style="margin-left: 40px; ">Set the wing halves on a flat surface with one tip blocked up and the other half flat</div><div style="margin-left: 40px; ">on the table.</div><div style="margin-left: 40px; ">44.</div><div style="margin-left: 40px; ">Raise the one tip 4" at the last W-2 rib. If the joint in the center does not match</div><div style="margin-left: 40px; ">perfectly, sand one or both center ribs until it does. Glue the halves together with</div><div style="margin-left: 40px; ">epoxy glue. Have a "wet" joint to insure that the glue will fill any gaps in the seam.</div><div style="margin-left: 40px; ">It is particularly necessary that the planking sheets, the spars and the leading and</div><div style="margin-left: 40px; ">trailing edges are thoroughly glued to each other. Take up the wing as soon as</div><div style="margin-left: 40px; ">the glue has set. It is easier to remove the excess that has squeezed out of the</div><div style="margin-left: 40px; ">joint if it is peeled off before it cures completely.</div>
Ken<br type="_moz" />
Yes , I see where you mean the two wings together now.. I was referring to the steps up to that part.. Like the spar doublers.. As I'm gluing these down with wood glue , I was wondering if it is going to be strong enough the whole time I was doing it.. Then I mixed a little Epoxy and seen how little coverage I was going to get.. I check back in the instructions again, just to make sure it doesn't call for Epoxy.. I didn't see it in any steps leading up to where I am.. So I went with wood glue
