OMG!!! thankyou!!!!!......thats awsome that will hepl in the future tho
only thing is it wont work with my setup [&o]
here is what ive got set up ATM, works a treat appart from the servo reversing
Its for a crawler with 4 wheel steering using the traxxas 5ch radio gear.
im using the 3 posi switch that controlles the 4th and 5th channel.
left position its just front steering
mid position front and rear steering turning opposte ways
right position front and rear steering turning the same way (this is the one that glitches)
im using 3 way switches as 2 way, and the "S tester" is a servo tester that holds the servo straight when the 1st switch cuts the signal wire.
im using the switched to controll the signal wire only, that way i dont have to worry about the servo pulling to many amps through the switches
