Servo reverser help
hey guys im doing a little project... details later....
Problem: Ive fitted a Turnigy servo reverser to a HPI SF1 servo using the traxxas TQi reveiver and the darn thing is glitching badly, any ideas?
OMG!!! thankyou!!!!!......thats awsome that will hepl in the future tho
only thing is it wont work with my setup [&o]
here is what ive got set up ATM, works a treat appart from the servo reversing
Its for a crawler with 4 wheel steering using the traxxas 5ch radio gear.
im using the 3 posi switch that controlles the 4th and 5th channel.
left position its just front steering
mid position front and rear steering turning opposte ways
right position front and rear steering turning the same way (this is the one that glitches)
im using 3 way switches as 2 way, and the "S tester" is a servo tester that holds the servo straight when the 1st switch cuts the signal wire.
im using the switched to controll the signal wire only, that way i dont have to worry about the servo pulling to many amps through the switches
here is the truck and the brain centre, when its all working correctly im going to tidy up the wires.
the servo tester sits in the truck tray, that way I can adjust the servo trim so its tracks correctly. plan to find a scale looking object to hide it so to change the trim u would just turn that.
hummm... dont know if I should try a different servo or order a different reverser?
im doubtfull another servo will be any different.
Why cant it just work GRRRRRRRR.... lol
ORIGINAL: phmaximus
Did you try bypassing the switches, and testing the servo reverser alone? If it works there seems like Switch 2 might be inducing some kind of interference into it.
yeah bud, tried that it does the exact same thing... its gotta be the reverser, but what saying it wont happen again if I get another one...
