RCU Forums - View Single Post - Which is lighter CA or Titebond?
Old 08-29-2012 | 04:05 PM
  #49
Gray Beard
My Feedback: (-1)
Default RE: Which is lighter CA or Titebond?
ORIGINAL: Jacobs Jasta 7
ORIGINAL: Lightspeed1551
CA is lighter. I have never broken a glue joint (CA or epoxy) in a crash it has always been in the area next to the joint.
Come to think of it, I haven't either. If the repairs are done right, it actually can become stronger and I think it is a misconception that repaired models become structurally weak. I'm not saying people should give their planes a CA or epoxy bath, but any brand of epoxy or CA will work well if applied right. I think brand is a matter of choice including what epoxy to use.
A ol'timer once told me that back in the 1950's when he was younger they put planes together with white wood glue. [X(] I don't think it would work with some of todays models- but what do I know. I'm just too chicken to try it and I'll stick with what I know works.
For me I use different thicknesses of CA for all the different types of applications I need it for. I use 30 min epoxy for the high stress areas and 6 min epoxy for the not so stressful areas, but need the strength that CA can't give me. Ultra thin CA for CA hinges or to make soft balsa stiffer, medium for the framing and some filling and thick CA for filling.
If I want to lighten up the epoxy and keep the same strength, or fill in those areas that have a gap then I will mix the epoxy with microballoons. Dents in balsa, I usually steam out with water and my covering iron. And I will use balsa filler for small holes or dents and cracks, (after mending it with ultra-thin CA) or use it to make sure I get a straight and level line removing slight skin warps on a smooth surface. (like using filler on a car body etc) The step by step method on how I use things is long and I don't want to bore anyone more than I already did. But keep reading the posts in RCU and RCG and you will learn a lot like I have over time, and you can decide what works best for you.
Everyone has their own way of doing things and none of them are wrong. I'm sure if everyone including myself can remember that, I think there would be less debates in the forums. For me when I build kits I usually use and do what the directions call for. It is rare that they are wrong, but that's why we have RCU and RCG build threads, so when there becomes a error in the directions we can spread the word a little better before there might be a Tech Update. When I ''Bash'' that's when at times I get a little more creative.
Over time everyone makes up their mind what works best for them in whatever application they are working with. Over time (things I must earn) in this hobby we all eventually learn what works, and from trial and much error what doesn't.
Pete
Why wouldn't Elmers work on todays models these days??? Did they change the formula of the Elmers or Balsa?? Just wondering, I use it more often then Titebond. I just used up a new bottle on a pair of planes I'm just finishing up. I used it to glue up the four strips of 1/8 balsa used for the LE of the wings. It holds as well as any of the wood glues and is easy to sand and plain. The one main reason I don't care for using wood glue is the warapage you can get due to the water in the glue. I do use a lot of CA but I have 6 or 8 different types of glue used in any given build.
HOW MUCH EPOXY IN ONE COMPLETE BUILD?? About 15 years worth.
I just used about 6 ounces of CA and about an ounce of Epoxy in this build including the floats. There was a lot of epoxy used in the gull sections, I use acid brushes to mix and spread epoxy. I buy several packs at a time at Harbor freight. Just starting to glass now. The other one is getting covered with TEX. This one is mine and it's fully sheeted and getting glassed. There were a lot of diffeent types of glues used in the builds. Bill what would you do about this dihedral???
