RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 08-30-2012 | 11:02 AM
  #679
Pull Up Now!'s Avatar
Pull Up Now!
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
ORIGINAL: captinjohn
ORIGINAL: gkamysz
Running methanol with spark is great. The engine designed for methanol doesn't have any trouble with the carb or cooling. They start easy and with spark run much leaner so you still save fuel. The power loss going to no nitro is small. If you can easily get no nitro fuel or methanol and mix your own it's just as convenient as getting a gallon of gasoline.
I just done some trading and now own a Saito 1.50 engine. My plan is to mix my own fuel and use a Rcxcel ignition or simular and Klotz oil. I may use a 16-1 oil ratio to start with. Any comments would be appreciated. Thanks Capt,n
16-1 oil ratio sounds a bit rich in oil. I believe at that level, you'll lose HP. I'd also recommend using regular gas pump gas (meaning oxygenated). The alcohol content will help cool the engine, and these Saito's do not like heat. Also, make REALLY sure you secure the Walbro (if that's your direction) really well. Any vibration on that cantilevered mass will cause it to vibrate loose and the resulting fresh air inrush will catastrophically lean the engine, ruining it, before you even figure out what's happening. I've seen this happen (not to me! I use RED loctite and a carb support bracket).
