RE: Help on engine cowling?
Hi!
Those would not hold it long! Problem is vibrations.
A much better way of holding a cowl is doing it like this.
3mm epoxy plates glued (24 hour epoxy finnishing resin and cut glass/carbonfiber ) inside the cowl using four metal screws screwed into the firewall. The cowl is secured through the front using a long screw driver.
