RCU Forums - View Single Post - G-38 question
Old 08-31-2012 | 11:05 AM
Mpizpilot
My Feedback: (45)
Default RE: G-38 question
ORIGINAL: CK1
It is possible that if the flywheel was a little loose the key could have sheared . Remove the prop hub and see if the flywheel is loose , then remove the flywheel and inspect the key and keyway.
That's exactly what it was, a sheared key though the flywheel was not loose.
