G-38 question
Old 08-26-2012 | 05:48 PM
My Feedback: (45)
Default G-38 question
My g-38 refuses to start suddenly after running for gallons. Pulled the cowl and prop. I can't seem to get the flywheel in the proper position in relation to compression/sensor pickup. Is it possible that somehow the crank has spun or something? This is my only zenoah/ magneto engine I've ever owned and can't figure this out.
Old 08-26-2012 | 06:15 PM
CK1's Avatar
CK1
My Feedback: (60)
Default RE: G-38 question
It is possible that if the flywheel was a little loose the key could have sheared . Remove the prop hub and see if the flywheel is loose , then remove the flywheel and inspect the key and keyway.
Old 08-26-2012 | 06:28 PM
My Feedback: (45)
Will do, thanks.
Old 08-31-2012 | 11:05 AM
My Feedback: (45)
ORIGINAL: CK1
That's exactly what it was, a sheared key though the flywheel was not loose.
Old 08-31-2012 | 11:34 AM
My Feedback: (45)
Ok, where can I find parts besides HH and graves rc? No one has the key in stock.
Old 08-31-2012 | 11:58 AM
acerc's Avatar
Go to Ace Hardware or your local lawnmower shop. Either will have those key's. At least around my area anyway.
Old 08-31-2012 | 12:24 PM
My Feedback: (45)
ORIGINAL: acerc
Interesting, running out now.
Old 08-31-2012 | 04:29 PM
My Feedback: (45)
Got one at ace! Thanks for the heads up. Had to grind it down a bit but I'm back in business
Old 08-31-2012 | 06:22 PM
acerc's Avatar
Very good. Happy flying.
Old 09-01-2012 | 06:58 AM
CK1's Avatar
CK1
My Feedback: (60)
Glad you got it going . The key shears from looseness but sometimes the keyway burrs a little when the key shears and make the flywheel seem like its tight . If it didnt require substantial pressure from a puller or a good hard wack from a mallett to pop the flywheel off - it was loose.
Old 09-01-2012 | 11:43 AM
My Feedback: (45)
It took a good wack with a mallet to remove it.
Old 09-01-2012 | 02:47 PM
acerc's Avatar
The flywheel would be tight after shearing, extra metal between it and the shaft.
Old 09-02-2012 | 06:15 PM
Iwill add my 2 pennys worth I have a 20 year ol 38 and the best way to reinstall the flywheel is heat it in toster oven just so it is to hot to handle about 150 deg's then quickly with a hot pan glovve the place it on th shaft and torque the prop hub to about 30 ft pounds use blue loc-tight on the threads. mine has never come loose sence doing this about 15 years back
Cheers and good luck
Bob T
