RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 09-01-2012 | 03:47 AM
  #682
Pull Up Now!'s Avatar
Pull Up Now!
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
ORIGINAL: captinjohn
Thanks spaceworm, that is waht I an looking for...the oil ratio and carb mounting is of great importance. Keep all the good data coming...I will use good advice anytime. Best Regards Capt,n
I forgot to mention in my original reply to Spaceworm more info about oil ratio. So far, in my Saito conversions, I've been using 32:1 non-synthetic Stihl "High Performance" oil, or equivalent. There is no synthetic content in that one. Lately I've been experimenting with HP "Ultra" full synthetic at 50:1 ratio. No conclusions yet, especially since most of my experiments have been on non-Saito 4-strokes. Another option is to try Stihl HP "Super" at around 40:1, but monitor the engine temperature with a non contact probe. The head is about 310F right at the exhaust outlet. The idea is to run an oil and a ratio such that you don't get carbon buildup around the valves. Otherwise, too rich on oil, and the valves will start leaking, losing compression.
