RCU Forums - View Single Post - primer on panel lines
Old 09-02-2012 | 12:48 PM
TJ FLYER
Default primer on panel lines
Hi, Just wanted to know what would be the right primer to use when spraying over panel line tape. A water base or oil base. If using enamel, will the tape peel off. I'll be using Benjamin Moore Aluminum enamel paint for the finish. thanks Tim.
