RE: Hangar 9 Katana 50. Which engine?
BCCHI,
Could you post how to get the DLE-20 to fit? I want to put this motor in my H9 Katana and it looks like you have to cut the engine box back or cut a big hole in it for the carb to go through. Also, is there enough room after that for the supplied fuel tank to fit? I do plan on changing the pull-pull rudder servo to the rear of the plane and change the elevator mini servos to standard size for balance purposes. It looks like my electric setup now will be almost the same weight as this engine with everything and fuel. Any info and guidance would be helpful as I don't want to purchase this engine if I can't make it fit and balance. Thanks.
