RCU Forums - View Single Post - Carf Paint match
Old 09-06-2012 | 03:16 AM
Andrew Bailey
Default RE: Carf Paint match
Hi GSR.
It looks like there are two versions of GM Torch Red. One has code 70-9075 and the other is 70-9076. Do you happen to know which of these is the match?
Andrew
ORIGINAL: GSR
If anyone is interested I have found the paint match for the commonly used red on Carf models. Eurosport, Old flash, Rookie and probably a few others. It is a GM color and is called Torch Red. Used on 1995-about 2002 or so Corvettes. It is a perfect match and any paint store can mix it with this info. If you want it in a rattle can DupliColor used to sell it but no longer make it. You can still find it around if you search. Scotty
<br type="_moz" />
