RCU Forums - View Single Post - Who else has failed on their first build?
Old 09-06-2012 | 12:50 PM
oliveDrab's Avatar
oliveDrab
Default RE: Who else has failed on their first build?
ORIGINAL: SeamusG
Do a search out in WWW land for ''Dean Pappas trimming from the ground up''. There is a set of 3 pdf files that help you understand how get things sorted out.
Btw, I was really nervous on the maiden of my 1st build, so much in fact, that I got an experienced club member to do the maiden for me. There are sooooo many little things that can bite a nice ''build'' squarely in the arse. Have a local builder do a ''tech inspection'' of your plane. You'd be surprised what we overlook 'cause we've been looking at it for a long time.
Sit back with an adult beverage and ...
<ul>[*]Make doubly sure that all of the throws are within spec. [*]Are all control surfaces tight? No slack when you grab the surface with your fingers and try to move it against the servo's resistance (off or on)<br type=''_moz''/>[*]CG? A tad nose heavy is a good start.[/list]
Oh, thanks for reference to Stevens - they are just down the road from me in ''the Springs''. I like to keep my $$$$ local.
</p>
That's some very good advice. I've got an electric F8F Bearcat with flaps, 72" span, retractable gear, 17.5 lbs. It's making me nervous.............so I'll take your advice.
