100 cc Sachs-Dolmar needs ignition module
I have a 100 cc Sachs-Dolmar engine with a smashed ignition module. The ignition timing is advanced via a tie rod to the carburator. A Hall's eye detects a magnet which is embedded in the thrust washer. I understand that more modern ignition modules work on electronic advancement. What ignition module should I use and where do I get one? Roger
