Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 100 cc Sachs-Dolmar needs ignition module >
Old 09-10-2012 | 12:55 PM
Default 100 cc Sachs-Dolmar needs ignition module
I have a 100 cc Sachs-Dolmar engine with a smashed ignition module. The ignition timing is advanced via a tie rod to the carburator. A Hall's eye detects a magnet which is embedded in the thrust washer. I understand that more modern ignition modules work on electronic advancement. What ignition module should I use and where do I get one? Roger
Old 09-10-2012 | 01:35 PM
All Day Dan's Avatar
Default RE: 100 cc Sachs-Dolmar needs ignition module
This guy has the best ones. Dan
CH Ignitions
For repairs and engine conversions use below address:
Adrian Ciulei
4753 Lakeside circle
West Palm Beach, FL 33417
Tel: 240 888 5902
Email: [email protected]
Old 09-10-2012 | 06:21 PM
Dan, thank you so much for the response. I placed a call to CH. They are temporarily closed because Bill has become ill. I will work on the Adrian Ciulei contact. This was my first use of any forum. I was so unsure of how it works. Pretty neat. Roger
Old 09-10-2012 | 06:29 PM
ORIGINAL: Roger Layton
My health has become better,but I am building very few ignitions and will not get back into the business.Contact Adrian Ciulei,he can build you a ignition with no internal timing control.Try ch ignitions not C&H Ignitions.
BCCHI
Old 09-10-2012 | 06:32 PM
Roger, thanks for the thanks. Bill has retired and turned the business over to Adrian. I have been using CH ignitions since 1995 and they are the only ones worth the expenditure of any money. You'll find that RCU is a great source of good information from across the USA and even further. I have benefited a lot from all the posters. Dan.
Old 02-16-2014 | 01:26 PM
vease's Avatar
i have two sachs 72cc engines. One ignition unit has an earth but the other doesn't. Should it??
Old 02-16-2014 | 08:37 PM
I would get rid of the mechanic timing. I never did like it
Old 02-20-2014 | 07:44 AM
My Feedback: (21)
Does one have a rubber spark plug boot and one have a metal boot? The rubber boot had an external grounding wire, the metal boots usually are grounded through the boot.
Old 02-20-2014 | 08:06 AM
vease's Avatar
I believe I've found the problem but am testing it Saturday so can report back then
Old 04-29-2014 | 06:07 AM
vease's Avatar
You were 100% correct on that
